Hi everyone,
I found no reason why, but sometimes Xnview creates small files, when IPTC-metadata is written into jpg files, one for each file. The newly created files are small, 1KB, contain only two characters (when viewed in a text editor) and are called ._01_filename.jpg (filename.jpg is the name of the actual image file).
1st question: Why does Xnview create those files? What are they for?
2nd question: How to disable this?
I already searched the web and the forum/newsgroup, but searching for "._" is not easy. And I think I'm missing the right key words, as the are no real sidecar files.
Thanks in advance,
Johannes
[Solved] Writing IPTC creates files with "._01_filename.jpg"
johannes.kastl
Last edited by johannes.kastl on Thu Dec 13, 2012 10:17 am, edited 2 times in total.
Re: Writing IPTC creates files with "._filename.jpg"
are you able to reproduce the problem?
johannes.kastl
With some of the pictures, yes. Other pictures are no problem.
The IPTC data is visible in the files, even if I delete the files. But if I add another thing in IPTC, there it is again...
Regards,
Johannes
Regards,
Johannes
could you send a sample file?
johannes.kastl
Hi pierre,
I'll try to find one I can send. How should I send it? To whom should I send it?
I noticed that I made a mistake in my OP, the filename of the sidecar is ._01_filename.jpg, I did not notice the extra _01_ at first, as our files are named beginning with 000_...
Regards,
Johannes
Regards,
Johannes
you can send it to contact at xnview dot com
johannes.kastl
Re: Writing IPTC creates files with "._01_filename.jpg"
Hello Pierre,
I sent a file this morning, did you get it?
Regards,
Johannes
Regards,
Johannes
johannes.kastl
I got a reply from Pierre, he thinks this was an issue with Version 1.96, which we use. I'll test the new version as soon as possible. Until then this issue is marked solved.
Regards,
Johannes
Regards,
Johannes
