I use XnView portable under Win 8 64bit enterprise and the associate image don't work
associate image don't work under Win 8
FlyAway
Hi
Re: associate image don't work under Win 8
even by starting it with admin rights? Do you have to use 'open with' from windows explorer?
FlyAway
yes and yes but the default program is the programm that have Win8
ok, i'll check...
FlyAway
I've tried on windows 8. I've installed the setup for xnview
double click on a picture, and windows 8 show me a menu with apps, and there is XnView...
FlyAway
thank's but the problem is with the portable version.
and...yes I also have the option for start with XnView but is not set in automatic, the option in XnView setting don't work
Can u post a .reg for associate the files?
