Using either "Browse with XnView" context menu item or trying to enter a network path manually in the address field, in both cases XnView's browser instantly opens "My documents" folder, not the necessary path.
I'm using v1.99.5 under Windows XP.
unable to browse any UNC network paths
CreativeWorld
Re: unable to browse any UNC network paths
and in the folder tree view you are able to find it?
