shows only one page of .fax creatix-fax file
desir
Post by desir »
hey, i have old Fax files from the balloon creatix software under win 3.1 which have the
ending .fax.
XNView just shows one page per file, even if ax contains more pages.
What can i do? (other program for windows 7 whith i checked didn't even show first page(irvan)
thanks a lot for the programm
desir
(willl a answer also be sent to my emailaddress or do i have to check this forum always for answers?)
Re: shows only one page of .fax creatix-fax file
could you send me a sample?
