Batch renaming in ver 1.99.5
disk
Hello @ all,
i use ver. 1.99.5 and with this version the batch renaming feature is not working.
Everytime an error pop up is shown.
Versions befor 1.99.5 behave correct.
Any suggestions ?
Disk.
Any suggestions ?
Disk.
Re: Batch renaming in ver 1.99.5
A crash?
Which settings do you use?
disk
Hi,xnview wrote:A crash?
i tried all of the settings ( date, exif, ascending, desending and so on ) and with every setting it is not working.
The company i work for has 1.98.9 i think and with this version everything works fine regardless wich setting i take.
Os here is win 7 with all available patches.
Disk
disk
disk wrote:Hi,xnview wrote:A crash?
Disk
i did some tests again and found that this "bug" is not program related, it is picture related.
But why ?
Newer and older pictures are involed, there is no clear pattern.
All are made with a Canon and a Panasonic cam.
disk
The pictures are not renamed?
disk
Yes, pop up box with " error during renaming".xnview wrote:The pictures are not renamed?
As i wrote in my last post some will be renamed, and some not, ending with that pop up box.
The feature for renaming a single picture is also involved.
disk
which template do you use? Could you post a screenshot of the dialog?
disk
Look here:
disk
disk
Sorry but i means a screenshot of the batch rename dialog
disk
Sorry,
a little misunderstanding.
disk
disk
If you try to rename only one file, you have the error message?
disk
1 or more files always the error message.
disk
disk
and if you copy this file in another folder?
disk
Ups,
that works.
Copied one pic to a different folder and it works.
It also works with more than one.
But why, did i miss something in the description ?
Did not try that before.
disk
that works.
disk
Not a right problem?
