Convert PDF to TIFF inc notes
RotBlitz
Post by RotBlitz »
What needs to be done to also "print" the notes/comments contained in a PDF document to an image like TIFF? Is this supported at all? Does this possibly require some Ghostscript configuration?
Thanks for any advice.
RotBlitz
Re: Convert PDF to TIFF inc notes
Currently not possible
Peter2
Post by Peter2 »
As (unhandy) workaround you could try to open the PDF with a PDF-viewer, print it to "PDF incl. Comments and Notes" and the convert it with NConvert.
Maybe it can help, maybe it is use- and senseless ...
Peter
RotBlitz
Post by RotBlitz »
Thanks for the responses. Printing is not an option, I want to do this unattended.
