"Print" window suggestion -> number of copies
klumy
- option to set "number of copies"
XNView 1.91.5
Windows XP SP3
Windows XP SP3
ckit
klumy
it owuld be good, if this option can be directly set in XNView. Otherwise I always have to change the Print Setup of XnView, if I want to change the number of copies.
It would be also great, if you could also change the printer in the normal "print" window without changeing the default printer in the normal" print setup window
XNView 1.91.5
Windows XP SP3
Windows XP SP3
