Not fixed bug: unable to move pictures in viewer after crop
rmtk
Post by rmtk »
I set my left button behavior to "move picture", so I can zoom and move a picture with a simple click and hold. But after a crop was performed, even though the picture was saved and moved to the next picture, the click&move stopped working. The only solution is to close the viewer tab and open a new one.
I have submitted this bug in: http://newsgroup.xnview.com/viewtopic.php?f=62&t=25626 , but not yet fixes in the new 0.53.
Re: Not fixed bug: unable to move pictures in viewer after c
I can't reproduce :(
rmtk
Post by rmtk »
And it is still in 0.61 :(
CreativeWorld
Post by CreativeWorld »
The problem seams to be related to the crop bar,
it cancels the functionality of zooming to 100%
when the left mouse button is set to "move picture"
and the left button is held down on the picture.
reproduced by:
1. tools > settings > keyboard/mouse: left button: move picture
2. zoom in or out so that the image isn't at 100%,
but keep the image smaller than the window,
otherwise the zoom functionality doesn't work.
3. hold down the left mouse button, the image zooms to 100%
4. release the left mouse button, the image returns to the previous zoom level.
5. make sure there are no selections on the image,
then open the crop bar by either pressing the crop button or choosing Edit > Crop,
the crop bar is displayed at the top.
Result:
The left mouse button doesn't zoom to 100% anymore,
To be able to zoom with the left mouse button again,
close the image tab and open the same or a new image.
The crop bar doesn't effect the ability to move the picture when
it's zoomed so that it extends outside the window.
tested with:
xview mp v0.61 on linux mint 15 cinnamon 32bit
rmtk
Post by rmtk »
And the edges look jaggy after crop...
CreativeWorld
It would probably also help the developer(s) if you'll post a screenshot, and an example file.
What steps did you perform that resulted in jaggy edges when the image was cropped?
rmtk
Post by rmtk »
OK. Here are the screenshots.
Look at the transmission lines. I just click the crop icon and then cancel it. No crop actually.
before
before
after
after
zxs
Post by zxs »
This bug still in 0.72 and 0.75 beta. Detailed description in the 4th post. Related only to the crop bar, if you first select an area and then crop, bug does not occur
zxs wrote:This bug still in 0.72 and 0.75 beta. Detailed description in the 4th post. Related only to the crop bar, if you first select an area and then crop, bug does not occur
linux too?
zxs
Post by zxs »
xnview wrote:linux too?
windows 8.1
rmtk
Post by rmtk »
Finally the long-lived issue related to the crop bar http://newsgroup.xnview.com/viewtopic.php?f=62&t=31725 seems to be fixed in 0.76. :D
But this bug is still there... :(
rmtk
Post by rmtk »
Still can not do the one click zoom&move after using crop bar. :(
For me this is the last unsolved major bug in 0.78 now.
See Issue 181 for details.
This problem is supposed to be fixed in v0.82 or later. Could you please check and confirm, rmtk?
rmtk
Post by rmtk »
Yes, it's now fixed. :D
