Interface change & LockZoomFlag in XnviewMP?
rfrank
Post by rfrank »
Hello again!!!!
I'll try to keep it short.... :P
On Xnview 1.9x.x I have my configuration like this:
As you can see, i have
1.- "Fit image to windows, large only"
2.- "Reset X/Y"
3.- LockZoomFlag=1 (on the xnview.ini file)... since I only keep the Zoom Lock behavior for one session.
However.... On XnviewMP, the interface changed to this one
Problem is, that I can't keep the changes made to the configuration, for example "ZoomLock" is ALWAYS on (ZoomLockFlag doesn't work in XnviewMP), and "Fit image to windows, large only" has to be setup on every session start.
My questions are....
1.- Is it there any way to setup my XnviewMP exactly the same way as my Xnview 1.9x.x?
2.- Could it be possible to leave the "Auto image size" menu INSIDE the options windows instead of a menu? (as in Xnview 1.9x.x)
Thanks again Pierre for your hard work on this program!!!!!!
