I'm a Xnview user from very old vesions, and I missing a very simple suggestion:
- In batch mode, when I set SAME DIRECTORY OUTPUT, I need to overwrite one-by-one selected image.
Could you add a OVERWRITE ALL button?
Request for BATCH MODE
ckv
Re: Request for BATCH MODE
There is an Overwrite drop-down list in the batch processing dialog, where you can select the default operation for files that already exist.
Or do you mean something else?
danicasati
I know that option.
But if I select OUTPUT folder the same that INPUT, I need to confirm every file to overwrite one by one.
It would be nice to put a new button, OVERWRITE ALL when program prompt to overwrite the first file.
- Forum Librarian
