XnviewMP 0.53 batch convert watermarking bug
Jou
Post by Jou »
The script says "watermark, lower left", especially see size="0" option:
<?xml version="1.0" encoding="UTF-8"?><XnView_script version="1.0" name="Logo+jpg">
<Watermark filename="D:/jou gmx.net wb.png" opacity="15" no_alpha="false" position="6" delta_x="0" delta_y="0" size="0"/>
<Output folder="" filename="" case="0" format="JPEG">
<Options overwrite="0" orgDate="false" keepMeta="false" keepICC="false" keepFolder="false" delOrg="true" multipage="false" allPages="false" openExplorer="false" clearItems="false"/>
<JPEG quality="70" progressive="false" optimizeHuffman="false" rebuildThumb="true" orgQuality="false" DCTMethod="0" subSampling="0" smoothFactor="0"/>
</Output>
</XnView_script>
Load the script, and it will behave like we have set size="1" option:
<Watermark filename="D:/jou gmx.net wb.png" opacity="15" no_alpha="false" position="6" delta_x="0" delta_y="0" size="1"/>
So when loading a script the size option is interpreted wrong or ignored, leading the watermark to be repeated all over the picture.
Gaming in 4k / 6k / 8k / 15k / 16k? Yes! https://joumxyzptlk.de
Re: XnviewMP 0.53 batch convert watermarking bug
yes right
@Pierre: Did you fix this problem?
helmut wrote:@Pierre: Did you fix this problem?
for me, yes
