Application Crash on win7 64 (MOV)
eagle3555
Post by eagle3555 »
Hallo :-)
My Version von xnview is 1.99.6
If i will open an Folder with pictures and also *.mov - then crashs xnview with following answer from win7:
Problemsignatur:
Problemereignisname: APPCRASH
Anwendungsname: xnview.exe
Anwendungsversion: 1.99.0.0
Anwendungszeitstempel: 50d03d0f
Fehlermodulname: QuickTime.qts_unloaded
Fehlermodulversion: 0.0.0.0
Fehlermodulzeitstempel: 50890e53
Ausnahmecode: c0000005
Ausnahmeoffset: 669fcce9
Betriebsystemversion: 6.1.7601.2.1.0.256.48
Gebietsschema-ID: 1031
Zusatzinformation 1: 6bcd
Zusatzinformation 2: 6bcde7812013385e3f8c6e4751551664
Zusatzinformation 3: 64b6
Zusatzinformation 4: 64b69ecd2393bd16bf6717d7bc940eed
Lesen Sie unsere Datenschutzbestimmungen online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0407
Wenn die Onlinedatenschutzbestimmungen nicht verfügbar sind, lesen Sie unsere Datenschutzbestimmungen offline:
C:\Windows\system32\de-DE\erofflps.txt
Is this a Problem of xnview or win7?
What can i do?
Thanks
eagle3555
Re: Application Crash on win7 64 (MOV)
Do you have Quicktime codec?
eagle3555
Post by eagle3555 »
Quicktime V. 7.73.80.64 is installed. I think the codec is also installed with this application.
Otherwise K-Liete-Codec-Pack 6.2.0 (64Bit) and K-Lite-Mega-Codec-Pack 8.7.0 is full installed.
Small info...
If i start xnview over doubleclick of a *. jpg and scroll through a folder with always *.mov in - the *.mov will correctly viewed. Xnview crashs only by closing xnview.
If i start xnview and go over explorerview in a folder with *.mov then crashs xnview immediately without viewing *.mov or other.
By
eagle3555
could you send me a mov that crash xnview?
eagle3555
Post by eagle3555 »
xnview wrote:could you send me a mov that crash xnview?
Happy new year :D
Yes i can, but how? I found no option to attach files.
eagle3555
by email contact at xnview dot com
eagle3555
Post by eagle3555 »
there is no problem anymore....
my quicktimeinstall has an error
after reinstall no problems with xnview
thanks pierre for help
eagle3555
Moscow
Post by Moscow »
I have the same problem at Windows 7 Ult SP1 + latest XnView.
Installing K-lite mega and fixing errors with Codec Tweak Tool doesn't help.
Xnview crashes when I'm trying to browse my DMC-G2 cam folder which contains *.jpg & *.mov.
Mediainfo:
Общее
Complete name                            : F:\DCIM\111_PANA\P1110353.MOV
Format                                   : MPEG-4
Format profile                           : QuickTime
Codec ID                                 : qt
File size                                : 5,41 Мбайт
Duration                                 : 1 с. 0 мс.
Overall bit rate mode                    : Переменный
Overall bit rate                         : 45,4 Мбит/сек
Encoded date                             : UTC 2012-12-17 13:56:43
Tagged date                              : UTC 2012-12-17 13:56:43
Writing library                          : pana
Видео
Format                                   : JPEG
Codec ID                                 : jpeg
Bit rate mode                            : Переменный
Bit rate                                 : 30,3 Мбит/сек
Width                                    : 1280 пикселей
Height                                   : 720 пикселей
Display aspect ratio                     : 16:9
Frame rate mode                          : Постоянный
Frame rate                               : 30,000 кадров/сек
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 бит
Compression mode                         : С потерями
Bits/(Pixel*Frame)                       : 1.096
Stream size                              : 3,61 Мбайт (67%)
Language                                 : English
Аудио
Format                                   : PCM
Format settings, Endianness              : Big
Format settings, Sign                    : Signed
Codec ID                                 : twos
Bit rate mode                            : Постоянный
Bit rate                                 : 512 Кбит/сек
Channel(s)                               : 2 канала
Channel positions                        : Front: L R
Sampling rate                            : 16,0 КГц
Bit depth                                : 16 бит
Stream size                              : 62,5 Кбайт (1%)
Language                                 : English
Please try to reinstall quicktime driver
Moscow
Post by Moscow »
What is "quicktime driver"?
I know only QT codec, but it's installed correctly via latest k-lite mega codec pack.
Moscow wrote:What is "quicktime driver"?
Sorry Quicktime or QT codec from apple
You have only alternative Quicktime so i think?
Moscow
Post by Moscow »
xnview wrote:You have only alternative Quicktime so i think?
Yes, but this file is not QT, it's mpeg4.
Also, now I renamed *.MOV to *.AVI and xnview stop crashing.
In any case, only xnview crashes in the thumbs view mode. Other programs works well.
Oh ok, do you have last version of klite codec pack?
Moscow
Post by Moscow »
xnview wrote:Oh ok, do you have last version of klite codec pack?
Yes, of course.
But usually I don't use K-lite, so this problem was before I installed latest K-Lite Mega, and it's still exist.
and with lastest version, always a crash?
