0.53: Small UI inconsistency: Quick search icon
budz45
Post by budz45 »
The two below screenshots speak for itself :)
Basically XnViewMP 0.53 Browser is missing the little magnifying-glass icon for the "Quick search" that is used on Batch Rename/XnConvert. It's a really smart little icon nice addition to UI which should be kept :) Please fix minor mistake thank you.
Re: 0.53: Small UI inconsistency
I have not added it here, to have more space to enter text
budz45
Post by budz45 »
xnview wrote:I have not added it here, to have more space to enter text
I think you could still add the icon to the box because it looks clearer to user that it is a Filter search box.
For the Browser, why not simply make the space wider by increasing the box width?
Please consider
