0.53: Random quits/crashes
soulky
Randomly it seems as I cannot nail it down further Xnview MP simply quits when using the quick search input field. It does not happen every time, but some times. Typing the first letter is enough to make it quick without any error message.
Re: 0.53: Random quits/crashes
The problem was in previous version?
soulky
No, I cannot remember this problem in 0.51 or 0.39.xnview wrote:The problem was in previous version?
Vapavite123
Peut-être un début de réponse ici :
Perhaps begin to answer here:
http://newsgroup.xnview.com/viewtopic.p ... ch#p106916
De PBY
Happy New Year
De PBY
Bonne annéeAfter some more tests, it seems that the problem occurs when the user is going too fast: if a text is entered in the quick search while the images metadata are still loading, the loading is stopped and the search only goes on the already loaded metadata. Must change of folder for forcing a reload of metadata.
Either the quick search should be disabled during load, or the loading should be not canceled and the search redone at the end of the loading.
Happy New Year
'create whole folder' enabled? All thumbnails of your folder are created?
