0.53 File from custom filter won't open directly
SamKook
Post by SamKook »
I added tbn(which is simply a renamed .jpg) to the include custom filter and when I open them from outside XNviewMP, it will only start XNviewMP as if I simply opened the software(to the last opened folder) instead of opening the image file.
Once XNviewMP is opened though, I can browse to where they are and see/open them perfectly fine.
SamKook
0.56 File from custom filter won't open directly
Post by SamKook »
v0.56 still has the same problem.
Re: 0.56 File from custom filter won't open directly
And last version?
