problem with wallpapers function
FlyAway
Post by FlyAway »
two small problems, the first is that when you apply a wallpaper and then restores the previous everything works fine but the second time, with another photo, the program still applies the first photo that was set
Second problem is that the update check function does not work
Re: problem with wallpapers function
FlyAway wrote: Second problem is that the update check function does not work
What's happened??
FlyAway
Post by FlyAway »
normally when clicked on to "check for updates" I received a reply, but now any message does not appear.
FlyAway wrote:normally when clicked on to "check for updates" I received a reply, but now any message does not appear.
Strange, i've checked, and i have the dialog box...
FlyAway
Post by FlyAway »
maybe it's a problem that depends on my firewall, I will check.
You can check the function wallpapers?
FlyAway wrote:maybe it's a problem that depends on my firewall, I will check.
i'll check
Drahken
Post by Drahken »
re wallpapers: How soon did you change it again?
Xnview names the wallpapers based on dates (xnview_wallpaper_20100512.bmp for example). If you change the wallpaper more than once in the same day, the new one will overwrite the old one/s. This means that going back will always go back to {yesterday}, because the ones you set earlier {today} each ceased to exist when you set a new one {today}.
It would be better if xnview included a timestamp in the filename, but then again, people don't usually change their paper multiple times in one day. (I sometimes do when I'm trying to decide between 2 or more pics, which is how I noticed this issue in the first place. Since then, I just get around it be re-setting each paper manually.)
