It would be great if XnViewMP has an option to display current file name in titlebar, maybe in xnview.ini
Is there a way to show file name in titlebar?
danghm
In viewer mode, I must turn on infomation panel to know which file is currently showed, but it always turn off after XnViewMP exit.
budz45
Re: Is there a way to show file name in titlebar?
Yes for a future version I agree that this should come.
For now it would be good if it existed as an Ini Tweak option for the xnview.ini
However for the future, I would like to see a GUI setting for it exist in the same way that foobar2000 using codes (see below screenshot) would go nicely under XnViewMP's Settings>Integration GUI
BK201
Then we need a Titleformating too, that's a lot of work and probably useless, just display the file name is enough.
budz45
Yes true. But I wrote that a GUI version could be thought about for future.BK201 wrote:Then we need a Titleformating too, that's a lot of work and probably useless, just display the file name is enough.
So Ini Tweak with Titleformating for 'Filename only', 'Full File path' and 'Program version' - I'm thinking flexibility.
btw, I think the default 'Program version' that displays on title bar should be kept as the default just until the beta versions of XnViewMP are finished.
