I created a button which starts an external exe like x:\software\fun\test.exe.
But the "working dir / start in folder / execute in ..." can not be defined, and this is why "test.exe" has problems to find supporting files. Is there a way to define "working dir"?
Peter
Start external programm: Working dir
Peter2
Re: Start external programm: Working dir
not currenlty
perhaps i must use the pathname of xnview as current directory?
Peter2
??xnview wrote:... perhaps i must use the pathname of xnview as current directory?
For me, I do not understand in detail the Windows option "working dir" and so on, but here is my situation:
- I have d:\software\main.exe.
- (Normally) I have also d:\software\sub.exe.
Main.exe has the code: "if find sub.exe then ...."; and I thought it searches always in the same folder. Doubleclick on main.exe works fine, but starting main.exe from a button in XnView brings "sub.exe not found". It seems that main.exe runs in some temp-location or somewhere else ...
Peter
Ok, so i must use app dir as current dir
Peter2
Better to add an extra option where the user can define the working dir (with app-dir as default).xnview wrote:Ok, so i must use app dir as current dir
Peter
