Image info background can't be changed in compare mode
converter
Post by converter »
I've observed that the image info background colour in compare mode can't be changed,all modifications applied to the normal image view are also applied (all image info edits and custom fonts) in compare mode except the background colour,which stays white and that makes it pretty much unreadable.
If other info or screenshots are needed,please let me know-thanks.
Re: Image info background can't be changed in compare mode
you can change info background in View>Info>Background color
converter
Post by converter »
<Moderator's note: This topic is la duplicate, please add new posts in topic 'Changing image info background in compare mode?'.>
