0.51/0.53 winx64 EXIF data not printed
lk2000
Post by lk2000 »
I tried to print a custom thumbnail layout. Under each thumbnail the following caption should be printed:
Filename: {Filename With Ext}
Camera: {EXIF:Make} {EXIF:Model}
Software: {EXIF:Software}
Date Taken: {EXIF:Date Taken [d-m-Y_H-M-S]}
Date Digitized:{EXIF:Date Digitized [d-m-Y_H-M-S]}
Data Modified: {EXIF:Date [d-m-Y_H-M-S]}
The filename with extension only is printed below each thumbnail and everything else between the curly brackets is not printed. I tried the same with version 0.51 and 0.53. There is no difference. Could this be a bug? I use the insert button from the print Dialog to insert the data between the curly brackets. I only changed the order Y-m-d to d-m-Y in the Dateformat.
I hope this can be fixed. I need this to print Thumbnail Reports with the most relevant Exif data of JPG-files.
Re: 0.51/0.53 winx64 EXIF data not printed
Printing above EXIF information works fine for me in v0.84.
:arrow: Closed (Please post here in case this problem should still occur for you).
