[Partially fixed] RMB/MMB/LMB doesn't work in Slide Show
Dreamer
Post by Dreamer »
RMB context menu, MMB and LMB double click doesn't work in Slide Show (standard, not quick) - result - it's impossible to exit Slide Show with a mouse.
Dreamer
Same here---
:) Hello !
• Confirmed here under Win98SE…
:mrgreen: KR
ckit
Re: RMB, MMB and LMB double click doesn't work in Slide Show
Post by ckit »
Dreamer wrote:RMB context menu, MMB and LMB double click doesn't work in Slide Show (standard, not quick) - result - it's impossible to exit Slide Show with a mouse.
I can confirm too.
Right, so MMB or LMB to quit the slideshow??
Left for me…
:arrow: Pierre
:) Hello,
- Personally, I would prefer the Left mouse button, because here the MMB has the original "four directions" scrolling-feature, so it's rather messy to use the click…
:mrgreen: K R
Dreamer
Post by Dreamer »
Yes, MMB and LMB double click, not LMB single click since users could accidentally click twice and result could be stop and start Slideshow again - if special mouse "Button find" feature is enabled (tested with one image in Slideshow).
Clo,
if you have MMB set to scroll image, that setting would be independent on your setting in mouse properties I think. You can check it - press MMB in fullscreen - if you don't leave fullscreen that setting above will be independent.
Not handy for me
:arrow: Dreamer
:) Hello !
- The MMB is set in the Logitech ™ soft setting, and it stays in XnView, like in all programs; hence, if I want to use the MM click, I have to click twice to set a click, plus twice to close the slide show >> back to View mode, for instance. Here, the Logitech setting takes precedence always…
:mrgreen: Kind regards,
Dreamer
Re: Not handy for me
Post by Dreamer »
Clo wrote:- The MMB is set in the Logitech ™ soft setting, and it stays in XnView, like in all programs; hence, if I want to use the MM click, I have to click twice to set a click, plus twice to close the slide show >> back to View mode, for instance. Here, the Logitech setting takes precedence always…
Therefore MMB click and LMB double click should be added - and maybe also RMB single click (to quit the slideshow) - but context menu with just few options (next, prev., first, last, FS/window, pause/cont., close, exit) would be better.
Dreamer
Post by Dreamer »
Partially fixed in 1.80.1:
- LMB double click to exit Slide Show has been added
...but I suggest to remove LMB single click to go to prev. file (also RMB to go to next file), since it's confusing (at least if it is disabled in options...)
- MMB double click to exit Slide Show has been added, I'd prefer single MMB click, same as Exit FS
This is probably feature, not bug...
Dreamer
