Greyscale PNGs
Greyscale PNGs
Decreasing the color depth of logo.png (32-bit RGBA incl. pHYs + iCCP + cHRM chunks) gives me varying results:
  • XnView MP v0.53
    • Image » Change color depth...
      • Greyscale [256]
      • Dithering [none]
  • XnView v1.99.6
    • Image » Convert to Grey » 256 Grey scale
Even if I remove the alpha-channel transparency first (by changing the color depth to 24 bits), MP produces different PNG output (compression level 9):
  • XnView MP v0.53
    • Save as...
      • 6661 bytes
      • 8-bit greyscale
      • pHYs + iCCP + cHRM
    • Export...
      • 8179 bytes
      • 24-bit truecolor
  • XnView v1.99.6
    • Save As... = Export...
      • 4042 bytes
      • 8-bit greyscale
Related post: Editing an images loses its transparency
