Ignoring Ctype option?
Post by Guest »
G'day all,
I tried the following, but unfortunately, the image created was only greyscale. Am I doing something wrong, or is this a bug?
./nconvert.exe -v -ctype rgba -o test.raw -size 12288 -out raw -resize 128 96 TestImage.cin
Thanks
Dave
Re: Ignoring Ctype option?
Anonymous wrote:G'day all,
:bugconfirmed: this option is only used in input
Post by Guest »
So is there a way to define the output format??
Thanks
Anonymous wrote:So is there a way to define the output format??
I fix this problem
Post by Guest »
I fix this problem
Ok, thanks :D
Dave
