Have done Image > Add Text... > OK. But can't see text on picture. What doing wrong?
Tks...Joe
Can't See Text
Drahken
Re: Can't See Text
It might be that the font you're using is too small to be seen. Under the 3 color boxes you'll see "font" and a button "choose", click the button to change the font size.
If everything is working properly, the text will appear on your cursor & will follow your cursor around until you click the image somewhere to lock it into place. If your mouse isn't over the image, the text won't be visible.
joehonl
Re: Can't See Text
Thanx, Drahken! How simple it is when the trick is explained. Didn't realize it needed such a big size (72!); guess it matches the size of the picture.
Aloha...Joe
Aloha...Joe
