NConvert Orientation after rotating
unbewusstsein
Post by unbewusstsein »
First, i have an image with :
    Format               : JPEG TrueColor (v1.1)
    Width                : 4288
    Height               : 2848
    Orientation          : Top Left
which I rotate according to exif by :
$ nconvert -jpegtrans exif -o 10-42--DSC_0193-rotated.JPG 10-42--DSC_0193.JPG
afterwards, i read info (of '10-42--DSC_0193-rotated.JPG') giving :
    Width                : 2848
    Height               : 4288
notice width and height are truly interchanged but Orientation remains the same.
is this an already reported bug ?
I'm using :
** NCONVERT v6.17 (c) 1991-2011 Pierre-E Gougelet (Sep 17 2012/10:53:49) **
        Version for MacOS X  (All rights reserved)
if reading info from another file from which exiftool gives :
Orientation    : Horizontal  (normal)
nconvert gave me, badly :
Re: NConvert Orientation after rotating
The rotation doesn't change orientation flag
lesleyb
Post by lesleyb »
RE: The rotation doesn't change orientation flag
I was racking my brains over this, I spent all last night trying to figure it out and concluded it must be a bug. Thanks for clearing it up!
