Auto image size is set to "Fit image to window, large only" and resets to "No fit" after moving the image. Therefore, the Image doesn't fit to screen after switching to fullscreen mode.
How to reproduce:
1. move image by mouse in viewer.
2. switch to fullscreen mode, the image remains of viewer's window size.
3. in order to fix size, need to switch to another image, then back.
The images are larger than my resolution.
0.53 win7x64 Auto image size resets to "No fit"
Re: 0.53 win7x64 Auto image size resets to "No fit"
If you zoom to your picture, 'not fit ' is used, so it's normal
