First of all, XnView is first class viewer with so many options that one could eaisly sunk in them!
I have a wide gamut Eizo monitor and I'm on OSX. I have selected ICC profile for my monitor in options.
Now, when opening picture, XnView does not apply display profile to that first image. If I press go to next or previous it does refresh image using the profile.
On first opened image, I need to press CMD+R to reload image and then ICC profile is correctly applied to the image.
Can you check this odd behavior out please?
Thanks
ICC profile not refreshed when loading image on wide gamut
anarti
Re: ICC profile not refreshed when loading image on wide gam
If you restart XnViewMP, do you have always the problem?
