Scanning of multiple pictures
Ember
Post by Ember »
Hi there! :)
I've been using XnView for many years and I'm pretty happy with it. But now I have a problem I somehow cannot solve myself.
I used to use XnView to scan pictures because of the auto detection and the possibility to scan multiple pictures at a time. Yesterday I tried out GIMP for it but removed the program shortly after because it's just too much for me. :wink:
From then on I only get the Windows scan and fax application to work:
So, my question is: How can I get back the functions? Also whenever I check the box for "Add XnView to application for USB events (camera, scan...)" the box is unchecked whenever I look back again.
What can do?
I currently use Windows 7, if that helps.
I really hope you can help me out.
Greetings from Germany
Marcus
Re: Scanning of multiple pictures
Do you have tried by strating XnView with admin rights, to be able to change this setting?
Ember
Post by Ember »
xnview wrote:Do you have tried by strating XnView with admin rights, to be able to change this setting?
I just tried but the box is unchecked again. :(
Ember
Post by Ember »
No idea how to fix this problem?
you have this problem since you have installed gimp?
Ember
Post by Ember »
This topic can be locked. I used a restore point and everything was back to normal.
