Add menu "Print" in viewer mode
Serezha
Post by Serezha »
Hello! It would be convenient if when viewing photos in a mode VIEWER it was possible to print a photo at once.
Peter2
Re: Add menu "Print" in viewer mode
Post by Peter2 »
EDIT: Removed posting because of confusion XnView / XnViewMP.
Peter
budz45
Post by budz45 »
It will come...I seem to remember Pierre saying somewhere that "Print" in the view mode is slightly different as it is processed more through system memory.
budz45
Post by budz45 »
Thanks, this has now been added in MP 0.56, but needs two small fixes (see below)
1.) Print needs to be greyed with 'Empty' tab
2.) Print NEEDS to be greyed out on Unsaved Capture (screen capture, web capture) as currently there is a Crash!
3.) Print NEEDS to be greyed out for Unsaved Clipboard image (Import clipboard)
4.) Although Pierre has to fix a tiny issue wrong icon (the correct Print icon is used in Browser)
wrong icon used for "Print" in MP 0.56
JohnFredC
Post by JohnFredC »
budz45 wrote: 2.) Print NEEDS to be greyed out on Unsaved Capture (screen capture, web capture) as currently there is a Crash!
It would be great to print an unsaved image that is never intended to be saved permanently. So perhaps just fixing the crash would be better for most users.
If that requires XnView to save a temporary image so that printing can proceed, so be it, as long as the temp image is automatically deleted thereafter.
John
peterbonge
Post by peterbonge »
budz45 wrote:...
And "Print" doesn't get translated. It should use the same string like in browser mode.
Regards,
Peter Bonge
