Using 0.53 win_x64.
I have been rebuilding EXIF thumbnails for my photos. I open a folder and do select all. It seems that if the folder also contains a movie(s) (.mov) then the metadata and jpeg lossless transformation parts of the menu are greyed out. I can then select a single file and reselect all and they are ungreyed and I can rebuild the thumbnails. It seems the greying out only happens the first time a folder is selected - you can go back to previously opened folder and no greying out after select all.
It makes some sense for the menu options to be greyed out because they don't apply to .mov files. However, just ignoring these files and allowing the operation is very convenient - BTW, I was surprised these operations weren't available in the batch processing options.
Thanks for a great program, now I have it I can see I'll use it a lot.
Simon Liddington
Bug in menu greying after select all
