0.51 Ubuntu: Can't open files containing spaces
brigantino2
Post by brigantino2 »
I'm using XnView (0.51) as my favuorite image viewer on Linux Ubuntu. I've noticed that if you open on an image file, sometimes the XnView window opens but the viewer doesn't start (the window stays blank). I've realized that this happens when you double click on a file whose name or path contains a space.
Thanks for your attention
Ale
Re: Can't open files containing spaces
ubuntu 64bits?
brigantino2
yes :)
Do you have installed with .deb?
brigantino2
I think so, as far as I remember
brigantino2 wrote:I think so, as far as I remember
There is a little problem in the xnview script that launch XnViewMP
CreativeWorld
Post by CreativeWorld »
xnview wrote:There is a little problem in the xnview script that launch XnViewMP
Are you able to fix this problem? When will be fix this problem?
with next version, but you can edit the script
CreativeWorld
Which script? What should I replace?
You can change in the /usr/sbin/xnview script, $dirname/xnview "$@"
mdalacu
Re: 0.51 Ubuntu: Can't open files containing spaces
Post by mdalacu »
It is working, thank you.
This is the modified file:
#!/bin/sh
export LD_LIBRARY_PATH=/opt/XnView/lib
export QT_PLUGIN_PATH=/opt/XnView/lib
if [ $# -lt 1 ]; then
  /opt/XnView/XnView
else
  /opt/XnView/XnView "$@"
fi
