0.53: Manage favorite folders
lian
Post by lian »
I cannot find where I can manage the favorites folders - delete, edit, rename and so on.
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
oops66
Re: manage favorite folders 0.53
Post by oops66 »
lian wrote:Hello,
Into a file :bookmark.ini , here: XnViewMP-051bookmark.ini ... so probably:XnViewMP-053bookmark.ini
lian
Post by lian »
Thank you - I suppose there will be something more convenient in the future ?
oops66
Post by oops66 »
lian wrote:Thank you - I suppose there will be something more convenient in the future ?
You're welcome - I hope too because, beside this file is not placed by default into the right folder here, if the setting "Folder for other files" = Program(XnView). Others Configs files are not located into the xnview.sh folder (but before - into "cd ..")
Related files:
XnViewMP-051default.bar
XnViewMP-051default.keys
XnViewMP-051layout1.dat
XnViewMP-051layout2.dat
XnViewMP-051style_sheet.qss
So these files should be located into the same folder as xnview.sh file, why this choose Pierre ?
