"Use different position/size for browser & view" problem
Hansen79
Post by Hansen79 »
XnView Version: 1.99.6
OS: WinXP
I watch an image in view mode ("fit window to image" active) then i go back to browser and browser window size is the same as view mode window
Re: "Use different position/size for browser & view" problem
how do you 'go back'?
Hansen79
Post by Hansen79 »
xnview wrote:how do you 'go back'?
Clicking on "browser button" on toolbar in view mode
and if you use Esc key?
Hansen79
Post by Hansen79 »
xnview wrote:and if you use Esc key?
With the Esc key it works properly
Thanks
