viewing TN files
fireman-175
viewing TN files
Post by fireman-175 »
I am hoping this software will allow me to view TN (Tractor northern) files on my Windows 7/64 Ultimate edition laptop. I believe these picture files are from my phone. Can someone explain if I can, and if so, the procedure?
thank you.
Re: viewing TN files
From what I can read in the list of supported formats, TN (Tractor Northern) format is not supported by XnView.
Typically, Pierre, the author of XnView, is always interested in supporting new formats, so you might just wait a bit for his reply, here. He might have a better answer or ask you for a sample file.
Related topic: Does XnView support graphic format .xyz?
Could you send me a sample file?
7roach
Post by 7roach »
I am hoping for the same thing. How can I send you a sample file? I'm new here, so I'll check for your contact info elsewhere too.
Thanks.
7roach
Post by 7roach »
7roach wrote:I am hoping for the same thing. How can I send you a sample file? I'm new here, so I'll check for your contact info elsewhere too.
Thanks.
I sent you a PM. Thank you for considering it.
Peter2
Post by Peter2 »
7roach wrote:...How can I send you a sample file? ...
See here: How to contact the author: http://newsgroup.xnview.com/viewtopic.php?t=1422
Peter
