Error when installing - Fedora 18
Navid
Post by Navid »
I'm trying to install XnConvert 64 bit on Fedora 18 from rpm file but I get this error:
$ sudo yum install ./XnConvert.x86_64.rpm
/*...just yum output here, nothing important...*/
Running Transaction Check
Running Transaction Test
Transaction Check Error:
  file / from install of xnconvert-1.51-2.x86_64 conflicts with file from package filesystem-3.1-2.fc18.x86_64
  file /usr/sbin from install of xnconvert-1.51-2.x86_64 conflicts with file from package filesystem-3.1-2.fc18.x86_64
Error Summary
("Error Summary" part is empty i didn't removed anything)
If any more information is needed just tell me.
Thanks for your help :wink:
Re: Error when installing - Fedora 18
Yes i know that RPM package is not good :(
Navid
Post by Navid »
It's good that you are aware, I hope my post help you to fix it.
I tried tar.gz file and it worked. I can run XnConvert, so I can use it. :)
Thanks anyway . :wink:
