UI display bug with unrecognized JPG
budz45
Post by budz45 »
Maybe a message could show on XnViewMP when jpg files that cannot open properly are opened.
here is the jpg file attached
Amber-rrrr.zip
budz45
Re: UI display bug with unrecognized JPG
Post by budz45 »
Thanks for adding the prompt message in XnViewMP 0.56.
Although you need to further make it so that the view tab auto closes after showing this message.
Theres no point in the tab still being opened after the message is shown.
Please fix, thanks.
How do you open the file?
You have no 'File can't be loaded'??
budz45
Post by budz45 »
xnview wrote:How do you open the file?
I drag & drop an animated .webp file (that is not supported by XnView or any viewer) from Windows Explorer to view mode
xnview wrote:You have no 'File can't be loaded'??
Yes the message does display fine :) ...
..However after the message is clicked 'ok' then the unopened file tab still remains open
budz45 wrote:..However after the message is clicked 'ok' then the unopened file tab still remains open
yes normal :) i have a little problem if i close it
budz45
Post by budz45 »
Hmm ok, so could you try making it transform into an Empty tab instead of closing it?
