Sometimes, Right-Click > Close = Crash! on Windows 7
kimi
Post by kimi »
Hi guys,
I know I'm really using quite old version which is 1.97.8 (Sep 2010) version and haven't updated for a long time due to being pleased and maintained file-type associated with a lot of effort. I don't know the following bug would apply to current version, so any test is welcomed.
Issue: Open "some" image file with XnView, right-click on it and open context menu, choose "Close" then XnView crashes with "XnView has stopped working" message, resulting with appcrash. Interestingly, if you close it via CTRL+W, no crash happens. I'm running on Windows 7 SP1. It happens randomly, but not always. And it doesn't happen when you close normally by clicking X on top-right corner.
Any ideas? Does it still exist in current version?
Re: Sometimes, Right-Click > Close = Crash! on Windows 7
But Crlt+W and Close is the same command, strange
Grey_rnd
Post by Grey_rnd »
Hello guys. Forgive for my bad English.
I have the same problem. OS windows 7 32 sp1 XnView 2.00
When viewing images or other actions crash program, in the previous version of the program such wasn't
Problem signature:
Name of an event of a problem: APPCRASH
Application name: xnview.exe
Appendix version: 2.0.0.0
Mark of time of the appendix: 5163de15
Module name with a mistake: StackHash_6bcd
The module version with a mistake: 0.0.0.0
Mark of time of the module with a mistake: 00000000
Exception code: c0000005
Exception shift: b8d0b2d0
OS version: 6.1.7601.2.1.0.256.1
Language code: 1049
Additional data 1: 6bcd
Additional data 2: 6bcde7812013385e3f8c6e4751551664
Additional data 3: 3db3
Additional data 4: 3db32a9845bebcc755d1426aafceb92f
prompt how to solve this problem. thanks
Are you using the russian version?
Grey_rnd
Post by Grey_rnd »
If it is a question of XnView, yes.
I downloaded from a site xnview.com the expanded version of the program, I installed and in settings I chose Russian certainly.
I installed the standard version problem the same.
P.S. You think it a transfer slip-up? Hmm... now I will pass for example to English, we will look as the software will work.
Please try again to download it, there was a problem with package... Or remove the exif_ru.lng
