MP Crash 0.53 - Similar Files function
foxyshadis
I've had occasional crashes with the similar files function on 0.51, but with 0.53 it seems to continually crash. I can't figure it out, it can read gigantic pictures (10,000x10,000) no problem but fail on folders that have 100 pictures with nothing above 1000x1000, all jpg. Is there anything I can do to help you fix the crashes?
quaid
Re: MP Crash 0.53 - Similar Files function
Try to backup your XnViewMP/xnview.ini file, then delete the original and restart whit clean configuration.foxyshadis wrote:I've had occasional crashes with the similar files function on 0.51, but with 0.53 it seems to continually crash. I can't figure it out, it can read gigantic pictures (10,000x10,000) no problem but fail on folders that have 100 pictures with nothing above 1000x1000, all jpg. Is there anything I can do to help you fix the crashes?
Check also the size of DB Cache.
Are you able to reproduce with smaller pictures?
