after cropping add original pictures canvas
mrbombay
Post by mrbombay »
Hello
When i crop the whitespace from white shoes it crops to mutch
is there a possible way to change canvas afterworths to 105% but the with original pictrue.
Do you understand?
Re: after cropping add original pictures canvas
Is this what you mean?
I've used 110% for clarity, and not tried to match the background colour.
Note that it's necessary to click on the arrow between the menu and the image to update the preview image.
Click on the image below to view fully:
mrbombay
Post by mrbombay »
That is ok, only it must be the original pictures that comes back... Not white colour.
You understand?
You could click on the colour selector 'Achtergrond kleur' and select a better background colour, but as the background colour is not uniform it could be difficult to obtain a satisfactory result in this case...
Actually using Red = Blue = Green = 250, for example, is not too bad:
