XnView keeps forgetting my settings
C0080900
Post by C0080900 »
I keep getting the "Other Apps" window every time I open XnView. I don't get it when I open images, though.
XnView also keeps forgetting my bookmarks even when I edit them, close XnView and re-open XnView/images via XnView.
I also keep getting notifications such as this one and similar notifications. It prompts me with the same notification even if I check the "Do not show this message again" option.
Downgrading back to 1.99.5 didn't help either, originally I was using 1.99.6, so I re-installed 1.99.6 since going back to 1.99.5 did me no good.
Any help, or is this bug relevant?
Re: XnView keeps forgetting my settings
Where do you save the xnview.ini?
C0080900
Post by C0080900 »
xnview wrote:Where do you save the xnview.ini?
C:\Program Files\XnView
What is your OS?
Peter2
Post by Peter2 »
C0080900 wrote:...Any help, or is this bug relevant?
a) Have you checked if you have the correct access permissions to the INI? For example Win7 does not allow writing to program folder without special permissions.
b) Try to define another place for the INI (drive d:\ or somewhere else ..) and test again.
Peter
C0080900
Post by C0080900 »
xnview wrote:What is your OS?
Windows 8 Release Preview.
Peter
Altering the permissions of the c:\program files\xnview folder seems to have done the trick for me, everything's working fine now.
Thank you for your support.
It's better to not save settings in 'Program files'
