XnView Manual does not open - PDF damaged?
al99337
Post by al99337 »
I downloaded the user guide, but when I try to open it I get the following error message:
"Adobe Reader could not open 'XnView (Windows) User Guide.pdf' because is either not a supported file type or because the file has been damaged."
I repeated the download with the same result. Any idea as to what I may have done wrong?
Al
Re: xnView Manual
ok, there is a problem, i'll check...
nevyoung
Re: XnView Manual does not open - PDF damaged?
Post by nevyoung »
Agreed it does not work. http://www.xnview.com/wiki/index.php?ti ... ow=breadth is the link.
BTW - thanks for a good program.
Peter2
Post by Peter2 »
nevyoung wrote:Agreed it does not work...
Because the file is empty ...
Peter
[email protected]
Re: xnView Manual
Post by [email protected] »
Any update on the problem?
Thanks
xnview wrote:ok, there is a problem, i'll check...
Re: xnView Manual
I've fixed it
[email protected]
Thanks Pierre!
Stef1786
Post by Stef1786 »
Is this the correct file?
I don't see much inside, all screenshots are missing, hardly any info at all.
Peter2
Post by Peter2 »
Stef1786 wrote:...all screenshots are missing....
Right, they exist only as link to the Wiki :(
Peter
