Contact sheet automatic filename generation
andrixnet
Post by andrixnet »
When creating contact sheets, assuming that there are more files then the number files that fit into one single sheet, XNVIEW asks for a filename for each contact sheet file to be created.
Considering a large number of files, this is impractical for the user.
I would suggest the following:
- evaluate the number of files given as input, calculate how many contact sheet files would be needed.
- ask for a filename prefix
- create each contact sheet and save it using prefix-number, where number is an automatically generated number starting from 1 and being 0 padded to the left with the proper number of digits according to how many contact sheet files need be created (and keep proper sortability order).
Re: Contact sheet automatic filename generation
andrixnet wrote:When creating contact sheets, assuming that there are more files then the number files that fit into one single sheet, XNVIEW asks for a filename for each contact sheet file to be created.
Thank you for your suggestions, andrixnet. Sounds like a reasonable workflow to me. The only thing is that most XnView dialogs support workflows but are not workflow based assistants. Means: I wished there were more dialogs that have workflow character, e.g. "Create webpage" is a clear candidate.
