Multiple directories choice for Move/Copy to...
lian
some suggestions for future versions on MP:
1. I have a "common" directory where all my image files ares downloaded and I need to move them to three distincts directories. Maybe it could be nice when moving/coping files with Ctrl+M (or C) to get the choice between the three last directories. So I won't have to chose each time a previous directory where to move these damn images.
2. managing the favorites. It lacks...
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
Re: multiple directories choice
For the recent directories you have the drop down list at the bottom of the screen, have you tried it? You can open it with mouse click or F4 key.lian wrote:Hello,
I agree.lian wrote:2. managing the favorites. It lacks...
lian
Yes, I use it... daily. But for my usage, I would be more convenient to have some rapid shortcuts to the last visited favorites. Clicking, selecting, it's just one click too much.helmut wrote:For the recent directories you have the drop down list at the bottom of the screen, have you tried it? You can open it with mouse click or F4 key.
O.k..lian wrote:Yes, I use it... daily. But for my usage, I would be more convenient to have some rapid shortcuts to the last visited favorites. Clicking, selecting, it's just one click too much.helmut wrote:For the recent directories you have the drop down list at the bottom of the screen, have you tried it? You can open it with mouse click or F4 key.
When using the keyboard for the whole moving/copying process, it is:
1. Alt+M (or Alt+C) for opening the "Move to..." (pr "Copy to...") dialog.
2. Cursor keys up/down for choosing one of the most recent directories. Or F4 to view the list and then cursor keys.
3. Enter key for moving (copying) the images to the chosen directory.
Not quite sure how this could be made even quicker/faster and flexible at the same time.
lian
Simple: when making Alt+M, it shows the 3 last used directories. You just have to click on the one you need. Only one click so it beats your solution
Your suggested solution solution does cover your use case, but will not fit for many other users. Dialog design must always balance between simple and fast usage and flexibility and universality. A software can fit well, but never fit 100% to all users needs. Otherwise you would need a custom-tailored software or an XnView with hundreds of options and settings.lian wrote:Simple: when making Alt+M, it shows the 3 last used directories. You just have to click on the one you need. Only one click so it beats your solution
Operating a user interface with shortcuts (keyboard), only, is much faster than using a mouse or switching between mouse and keyboard, btw.
lian
Well, if I don't ask for anything there is no chance I got it.
I suppose it's not so unusual as you are thinking. Look at Fastone Image Viewer: to move (or copy) a file, you type M - much more simple thant Alt+M - and a window with all favorites is showing. Much more easier to select a destination...
Right, sorry for defending the current user interface of Copy to... and Move to.... Your wish and description reminded me of the messy dialog of a popular graphic viewer, which I had seen some years ago (not sure whether this had been changed since then). Perhaps this explains a bit.lian wrote:Well, if I don't ask for anything there is no chance I got it.
Just had a look at FastStone's dialog and found it o.k.. There, both recent folders and favorites can be accessed in an even quicker way and can be operated using the keyboard (in theory, if you do try, you will notice that switching between History and Favorites is very difficult).lian wrote:I suppose it's not so unusual as you are thinking. Look at Fastone Image Viewer: to move (or copy) a file, you type M - much more simple thant Alt+M - and a window with all favorites is showing. Much more easier to select a destination...
As a first, small improvement in XnView I'd suggest to enable keyboard support for the favorites: Currently, you cannot open the list of favorites using the keyboard (at least, I didn't find a way). F4 key is used for opening the list on dropdownlists, the same should work on the favorites button.
Perhaps in the mid/long run there is more to do...
Why?2. managing the favorites. It lacks...
Favorites Popup menu is not good???lian wrote:Well, if I don't ask for anything there is no chance I got it.
lian
Re: Multiple directories choice for Move/Copy to...
Because you may have to delete some old favorites or edit them. The ability to change order of appearance could be nice too.xnview wrote:Why?2. managing the favorites. It lacks...
The pop up is good. I was speaking about what the pop up contains. It could list favorites or last folders used so it's quicker to move or copy images.xnview wrote:Favorites Popup menu is not good???lian wrote:Well, if I don't ask for anything there is no chance I got it.
By the way, I add one more proposition:
when batch renaming (F2), maybe it could be nice that the model name is preselected (I mean all the field).
But you can already delete or edit themlian wrote: Because you may have to delete some old favorites or edit them. The ability to change order of appearance could be nice too.
Sorry but i don't understand, what must be changed?The pop up is good. I was speaking about what the pop up contains. It could list favorites or last folders used so it's quicker to move or copy images.
lian
Default behaviour for F2: http://tof.canardpc.com/view/38bef96e-1 ... 906ae2.jpg
What I need: http://tof.canardpc.com/view/55e6cb83-1 ... d178a0.jpg
For the moment, it seems that the only way to manage favorites is to go in .ini file ? No ?
Oklian wrote:Default behaviour for F2: http://tof.canardpc.com/view/38bef96e-1 ... 906ae2.jpg
No in the favorite paneFor the moment, it seems that the only way to manage favorites is to go in .ini file ? No ?
lian
Oopsss. You are right. I've asked the question in the forum and someone told me I had to use the ini file... Thanks.No in the favorite pane
