Batch rename: numerator from a value
GillesT
Post by GillesT »
in my folder several imges e.g :
etc
In my output settings
If I write : image-# it will start naming from 0.
how can i do to start from n+1 ?
Thank you for your help.
Re: numerator from a value
in batch rename?
Assuming that you mean Batch renaming:
In Batch rename dialog, there is an text field labeled "Start". Here, you can set the start value of the enumerator.
GillesT
Post by GillesT »
Sorry, but english and me...
On graphic way, a possibility?
GillesT wrote:Sorry, but english and me...
It's much appreciated if people do write in English, because the audience is the largest. Questions can be also posed in French in the French forum. And if you speak German and really have trouble with English, you can contact me directly and write in German. (Sure enough still many important languages are missing).
A screenshot which shows the usage of the start number:
GillesT
Re: Batch rename: numerator from a value
Post by GillesT »
Thank you for your answer and the great job you do.
