Powerpoint files are unreadable with 1.80
Locked
Post by Guest »
When reading Powerpoint files (ppt, pps) the Warning is issued:
"Format of the file <filename.ppt> could not be determined"
I tested "Minimal version" and "Complete version" with the same result. Version 1.74 works.
I like new version anyway. Thanks, Filip.
Re: Powerpoint files are unreadable with 1.80
Anonymous wrote:When reading Powerpoint files (ppt, pps) the Warning is issued:
You must enabled options/General/Startup/All formats
Locked
