Moderators: xnview , Dreamer
pim
Posts: 27 Joined: Sun Nov 06, 2011 12:11 pm
Post
by pim » Tue Apr 09, 2013 3:06 pm
Hi.
When merging old picture collections I found two different pictures with same crc32 according to XnView:
Other crc32 tools show more believable values:
Do you want to check original pictures?
Version 0.92 x64 (Sep 29 2018) - un*x
Posts: 48839 Joined: Mon Oct 13, 2003 7:31 am
Post
by xnview » Wed Apr 10, 2013 6:19 am
yes please send me the pictures?
pim
Post
by pim » Wed Apr 10, 2013 2:57 pm
Post
by xnview » Wed Apr 10, 2013 6:06 pm
ok, thanks. Strange i have not same crc32 on windows, and which settings do you have for a result with these 2 pictures?
There aren't similar...
pim
Post
by pim » Thu Apr 11, 2013 2:48 pm
Lets compare if we have identical files also by another tool:
I'm getting the same result with default settings:
[nabuko@nabuko XnMP]$ mv ~/.xnviewmp/ ~/.xnviewmp_bck
[nabuko@nabuko XnMP]$ xnviewmp
I just checked "Same file data" in "Search similar files" dialog. Nothing else.
And here is extract from terminal output since comparison starts:
### ThumbLoaderThread :: stop() ok
QPixmap: It is not safe to use pixmaps outside the GUI thread
### MyBitmapView (35cf8a0) :: resizeEvent 244 64
### MyBitmapView (357da40) :: resizeEvent 244 64
LOAD BITMAP <//media/truecrypt1/PROGRAMY/Dropbox/Public/XnMP/184-8419_IMG.JPG>
GFF :: LoadThumbnail : 0
LOAD BITMAP <//media/truecrypt1/PROGRAMY/Dropbox/Public/XnMP/183-8385_IMG.JPG>
=> 0 1 b4002e90 (0)
###### LOAD BITMAP </media/truecrypt1/PROGRAMY/Dropbox/Public/XnMP/184-8419_IMG.JPG>
### resetViewport (35cf8a0) ==> 244 64 (85 64) 0 0
###### LOAD BITMAP </media/truecrypt1/PROGRAMY/Dropbox/Public/XnMP/183-8385_IMG.JPG>
### resetViewport (357da40) ==> 244 64 (48 64) 0 0
### MyBitmapView (357da40) :: resizeEvent 330 64
### resetViewport (357da40) ==> 330 64 (48 64) 0 0
### MyBitmapView (35cf8a0) :: resizeEvent 330 64
### resetViewport (35cf8a0) ==> 330 64 (85 64) 0 0
QSettings::endGroup: No matching beginGroup()
Post
by xnview » Thu Apr 11, 2013 3:31 pm
Very strange, i've tested on windows and linux, and i don't have same crc with similar dialog
pim
Post
by pim » Thu Apr 11, 2013 4:22 pm
It is...
Have you tried both 32 bit or 64 bit version?
What crc32 checksums are you getting?
Setup in english: Initial settings, select dir, open dialog and select Method. Nothing else.
Post
by xnview » Thu Apr 11, 2013 6:21 pm
Ok, with same file data, the crc is not computed!
Post
by xnview » Fri Apr 12, 2013 6:10 am
Ok, i've tried with other tool, and the crc32 is the same for these 2 files
pim
Post
by pim » Fri Apr 12, 2013 3:04 pm
Today I checked those files at different computer with different OS under different XnView version but with the same result:
v0.53
CRC32 checksum tool integrated into TotalCommander gives also same values (while in hexa):
; Generated by WIN-SFV32 v1.0
; (Compatible: Total Commander 8.01)
183-8385_IMG.JPG B700F1BB
184-8419_IMG.JPG B700F1BB
Seems like it's time for another checksum method:-)
But at least you know it's not bug in your implementation but rather design flaw in crc32.
