Very slow CR2 support?
CidelFastro
Post by CidelFastro »
Is xnView ever going to address the extremely poor performance rendering Canon Raw files? It's a great program otherwise
DOS386
Re: CR2 support?
Post by DOS386 »
CidelFastro wrote:extremely poor performance rendering Canon Raw files? It's a great program otherwise
Please supply an example file and performance details XN vs other program.
Performance for NEF files is also bad and XN is unresponsive:
http://commonsarchive.org/wiki/Category ... _NEF_files (15 MiB)
http://commonsarchive.org/wiki/Category ... _NEF_files (50 MiB) :shock:
NC is able to convert NEF into PNG ... but also takes some time ... "-info" is fast.
CidelFastro
Re: CR2 support?
The issue is that the program basically freezes when loading large raw files. When in the browser a folder with many raw files loads very slowly as does trying to view them usually freezing xnview
