How to use filter?
Mark S.
How to use filter?
Post by Mark S. »
I'm try to use "Custom" filter. I've added PDF to the first custom field under options.
But using custom filter doesn't change anything -- everything seems to display including mp3, exe, zip files, etc. Nothing gets filtered out.
Also the "include" and "exclude" terms not show on either of the custom set up fields.
The help file doesn't seem to provide any instruction on custom filters, tags, or categories.
This is vsn. 2.0.
Thank you,
Mark
Edit: Working at it. It appears that if you put in an Exclude extension, then it ALWAYS excludes -- even if you filter by "Images". This makes the custom filter crazy tedious to use. I would expect that if I use filter Images then it would show all images no matter what the custom setting is. Same for the "Videos" and "Sounds" filter. The custom setting would only matter if I chose the "Custom" filter.
Re: How to use filter?
What do you want to do?
Mark S.
Post by Mark S. »
A custom filter to show only JPG's, for instance.
unselect images, and add jpg in custom filter
Mark S.
Post by Mark S. »
xnview wrote:unselect images, and add jpg in custom filter
There's the problem. Instead of just clicking "Custom", I have to go and fiddle with the option settings. Kind of eliminates the point of a drop-down filter.
Thanks,
Mark
