Xnview 2.0 crash on hidden file
Ryrynz
Viewing this file when hidden property is set on my computer causes Xnview to crash and explorer saying "xnview for Windows has stopped working"
Re: Xnview 2.0 crash on hidden file
which OS?
You start with this file from windows explorer?
eL_PuSHeR
Unable to recreate. It works fine here. Open with -> Xnview. It works also fine from XnView file browser.
XnView 2.0.0.0 under Win7 x64
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
8 GB DDR4 (2100)
Ryrynz
Via Windows Explorer on 7 x64. I get the explorer error generally once the file has displayed.
Scouting around a bit I've found part of the issue, still not sure what's causing it but these two settings in the INI cause the error for me.
PlaySound=0 and ImageLoop=1 =Explorer error
Playsound=1 and ImageLoop=1 =No error
Playsound=0 and ImageLoop=0 =No error
Still have yet to test on my other machine, but will do that when I wake up, tested 1.99.6 and it had the same issue.
