I have used xnview and nconvert for a decade, thanks for all you have done!
I have been having an issue with xnview crashing in windows when launched from the start menu after a few seconds. I managed to narrow it down to the folder it was looking at. I have the DropBox app installed on my computer, if xnview launches and its path is the Public folder for dropbox it crashes. There is 1057 files in that folder. Is there any way I can provide you with enhanced log data of what is causing it to crash?
Thanks!
Crash in conjunction with dropbox
Re: Crash in conjunction with dropbox
Do you have only picture files?
rahlquist
No, there is a mixture of files. I will see tonight if I can narrow it down to a particular file.
